nokia Digitalreceiver Satellitenreceiver  d box1
Serverzeit: 18 4 2026  16:46:56      TV   VCR Aufnahme   TFT   CRT-Monitor   Netzteile   LED-FAQ   Oszilloskop-Schirmbilder
Digitalreceiver nokia d box1
BID = 40021
metropar
Hersteller : nokia
Gerätetyp : d box1
Chassis : d box1
i have a problem with a d box on jumper x06 i have
richt 12v only left i have 1.8v also i can put the boot in and out de box without using a jumper
when i put boot en soft into de box al free to air channels oke!
codeer channels black than i give many cam reset and init
dan codeer channel have pict. than zap to next codeer chan.
black screen
also many cam reset and init than get pict.
also the boot dosnt blinking in the display it burns
I put some nieuw 29f800 in the box same problem
please help thanks metropar
ps. sorry for(bad eng.) cant write german
BID = 40029
Satfan123
Sat- und DBox-Spezialist
your problem is to locate in the Gal section IP06-IP08 or the prozessor
take a look at the service manual at http://dbox.a-z-e.de/
BID = 40443
metropar
thanks satfan 123
I take a look on dbox a-z-e.de
bad the schematic are not good qualitie
from the schematic off the processor block I cant read
the part number off the trans. connect XP06-1
I think the type of the trans. are BC847b bad part number
I can not reed its like tp 02 and 04 I think
bad the can I not find on on the mainboard
mayby you now ware I cant find another schematic
greeting and thanks metropar
BID = 40468
Satfan123
often the IP 08 is defective the Gal IC
BID = 40643
metropar
to satfan 123
now I have a error : VCM 1
you now wath it means
thanks metropar
BID = 40649
Satfan123
hehe
this is an error in the video section
Saa chip or c-cube defectice ..
take the box and send it to our repaircenter
gerechnet auf die letzten 30 Tage haben wir 11 Beiträge im Durchschnitt pro Tag       heute wurden bisher 12 Beiträge verfasst
© x sparkkelsputz        Besucher : 191289765   Heute : 15328    Gestern : 20383    Online : 452        18.4.2026    16:46
